Repair, disassembly, and troubleshooting information for the Xiaomi Redmi A5 Android smartphone, including models 25028RN03A, 25028RN03L, and 25028RN03Y. It features a 6.88-inch display, UNISOC T7250 processor, 32 MP rear camera, and 5200 mAh battery.
Why is the phone not charging?
phone switched off after all power was drained now its not charging why ?
Add a comment
Most Helpful Answer
@antonioand26660 first check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Most likely parts to change are the charging board and the battery. Do not forget to check the flex cable from the charging board to the main board. Sometimes those get corroded or end up with micro tears.
Since iFixit does not yet have a specific guide for this, use something like this video
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Score 1
Add a comment
Why phone not charging
1 Comment:
@rakshithab92639, did you read the answer provided by @oldturkey03?
Did you go through the troubleshooting steps he suggested? If so, what did you find? If not, try reading the information already given rather than just asking the same question again.
by
Add a comment
Add your answer
Antonio Andy Lekuni will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 64
All Time: 116
