Up to 20% off select tools
The Dell Latitude 5440 is a 14-inch business laptop released in 2023. It features 13th-generation Intel Core processor options and is designed for professional and everyday use.
pink screen flickering problem
pink flickering screen i try to uninstall and install again my gpu its still not work
Add a comment
1 Answer
Most Helpful Answer
@princedion96322 pink and flickering is commonly a failure of the LCD. Connect an external monitor to your laptop and see what that displays. If it displays normal then you know the issue will be with your LCD. If an external monitor displays the same pink screen then the issue will be related to your motherboard i.e. GPU etc. Let us know what you find out.
The Latitude 5440 Manual is also a decent service manual and page 89 will show you how to work on your LCD if needed.
Score 1
Add a comment
Add your answer
Prince dion Calapan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 117
