Boot not opening on 1series
@thatopie you are not giving us enough information. We need to know if the tailgate does not open with the key fob, the interior button, or the rear emblem badge. Or if it is only one of those that does not work.
If it does not work with any of them it is most likely an electrical problem. In order to open the hatch you would need to:
Once opened you can start inspecting why it does not work. Start with the wiring since the wires running from the body to the tailgate flex every time you open the boot :-). Over time, the wires can become brittle and break. Open the hatch and look at the rubber boots at the top hinges. Pull the rubber boot back and check the wires inside. If you see broken wires or exposed copper you will need to splice and repair the broken wires.
If the wires are intact (or if a broken wire shorted out the system), check the fuses. The tailgate latch is powered by the Rear Electronics Module (REM), located behind the carpet lining on the right side of the trunk. Since you did not give us the model year, check the fuse diagram for your specific year on something like this site. For example, on a 2018 you would need to check Fuse #107 in the fuse box in the luggage compartment
Water damage is very common in the BMW badge mechanism. If the key fob opens the hatch but pressing the BMW badge does nothing, the microswitch inside the badge has failed. You can unbolt the emblem mechanism from the inside of the tailgate and test the switch pins with a multimeter for continuity when pressed.
If the wiring is good and the fuses are intact, the motor inside the latch assembly may have burned out or the gears may have stripped. Unplug the connector at the latch mechanism and test for 12V while a helper presses the key fob release button. If you are getting 12V to the connector but the latch does not move, the actuator has failed and needs to be replaced.
Let us know what you find out.
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 76
All Time: 429
4 Comments
In order to help you we will need more information, what do you mean by "boot".
by Albert Einstein
@alberteinst6187 that is the trunk of a vehicle. For this BMW it is actually consider the tailgate. Welcome to a true global community :-)
by oldturkey03
@oldturkey03 Well TIL that it is called something other than a trunk, :)
by Albert Einstein
Is it not opening at all. . You can’t unlock it?
If it’s this, you will need to check either the release latch in the drivers compartment or if you don’t have this, check the remote switch on your keys. If you don’t have this, you might want to find the emergency release cable. You will probably need to drop the back seats and check the manual first! Then spray the mechanism with good old WD40 that some fab kit!!!
Or it difficult to lift open?
If it’s difficult to lift you will probably need to replace the gas springs, lift supports, or boot struts). the assist with lifting the weight of the boot.
by Phil Lopez
