The Mitsubishi Outlander, which first debuted in 2001 (originally as the Airtrek), has evolved through four generations into a versatile compact-to-midsize crossover. The latest generation (introduced in 2021) utilizes a chassis shared with the Nissan Rogue and a robust 2.5L four-cylinder engine producing 181 hp.
How can I change the engine oil?
I want to change my engine oil by myself
Score 2
1 Comment:
Hi @mahyarpejam
What is the year and engine capacity e.g. 2.4L, 2.5L, 2.2L(diesel) of the vehicle?
by
Add a comment
1 Answer
If you have access to the underside of the car, you should unscrew the oil tank to drain the oil, and also open the engine cover itself, where you can pour oil, and you're done.
Add a comment
Add your answer
Mahyar Pejam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 167
