How to remove pink lines from screen
My laptop screen has some pink horizontal lines at the bottom. How can I fix this?
Ouch! Lines tend to be a damaged LCD panel. You'll likely need a new display to fix it. To be sure connect your laptop to an external display if the image there is the same with pink lines that you have a logic board issue otherwise you've proved the disp,ay is damaged.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 69
