Tmr replacement in duelsense v2
I put in new tmr sticks in my duelsense v2 controller. I accidentally stripped out the through hole for the middle pin on the right of the board but it came out whole so I took it and pushed it back in the hole. Now after fully soldering in the tmr stick that one is hard stuck to the left when trying to calibrate it.
10 Comments:
Hi!
Can you upload some pictures regarding the solder work? This way we can check the damage and we may help you further.
Adding images to an existing question
Thank you!
by
Uploaded a picture
by
Hi!
Thanks for the pictures! Can you show us which hole was damaged? Also I can see some damage at the connector left. Is that one working fine?
Thank you!
by
The one on the left seems to be working fine when I run the calibration. It was either the middle pin on the bottom or the middle pin on the right on the right side of the board that the through hole accidentally stripped. When trying to calibrate it, that stick will move up and down to an extent but keeps to the left and won't move right
by
I got it fixed
by
Show 5 more comments
Add a comment
