{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
Keyboard and trackpad does not work at all.
Hi everyone,
I’m looking for some help with a MacBook Pro 13” Retina (2017, Touch Bar model).
I recently replaced the battery. The replacement went smoothly, and after reconnecting everything and checking the connections multiple times, the MacBook powers on normally and correctly recognizes the new battery.
However, since the battery replacement, I’ve been experiencing the following issues:
  • The keyboard does not work at all.
  • The trackpad does not work and does not physically click (it feels completely locked).
  • The right cooling fan does not appear to work properly.
  • On every startup, the left fan immediately ramps up to a very high speed and keeps spinning loudly, regardless of system load.
The MacBook itself boots and operates normally with an external keyboard and mouse, and the battery is detected correctly by macOS.
I’ve already reopened the MacBook and checked the battery and flex cable connections, but I haven’t found anything obviously disconnected or damaged.
Has anyone experienced something similar after a battery replacement? Could this be related to the trackpad flex cable, keyboard/trackpad connector, fan connector, or perhaps a sensor that is no longer being detected?
Any suggestions would be greatly appreciated. Thanks!
Add a comment
Carefully go over the guide for reconnecting and securely latching down all the components MacBook Pro 13" Touch Bar 2017 Teardown. I can be helpful if you can take some clear pictures of the keyboard and track pads connectors and cables so we can see if anything has deformed in the repair attempt. It seems to me that these components in question haven't been connected correctly or their connections are damaged.
Add a comment
There are two logic board cables that maybe damaged, one connects to the trackpad MacBook Pro 13" Retina (Touch Bar, Late 2016-2020) Trackpad Cableand there is a second cable which connects the keyboard and fans MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Keyboard Cable
inspect the logic board header contacts for damage bot the cable and board.
Replace the flex cable that connects the trackpad to the logic board compatible with the Late 2016 to 2020 Retina Touch Bar MacBook Pro 13 inch laptop. Part #821-01063-01, 821-01701. Image
Product
$9.99
Replace a damaged or torn keyboard cable compatible with a 2016 or 2017 model 13" MacBook Pro with Retina Display and Touch Bar. Image
Product
$9.99
Add a comment
Add your answer
Gabriele Suergiu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 83
