Even after changing compressor AC is not working
I got 2010 mazda 3 GS new compressor was installed, 1 whole day AC worked amazing. Next day AC stopped working and blowing hot air.
The most likely problem with vehicle ac failure is the leak no one wants to find but will attempt repairs that fails. If Mazda installed dye in the ac system, leaks will release refrigerant (invisible gas), oil and dye. Oil and dye will mark leak areas. Dye may be greenish yellow and glow brightly with an inexpensive uv blacklight. Find the leaks and make repairs to allow full restoration. I presume oil was replenished, new O-rings and any flat seals replaced. Every system must be repaired and sealed to retain refrigerant under pressure or it will leak out. Vehicle ac repairs are not diy friendly.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 79
