The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
Problem with replacing the right conductive film
Hi everyone, I'm repairing my PSP 3004, which had broken X and Square buttons.
I ordered a replacement conductive film and reinstalled it, but using a control testing tool, I noticed that the R2 button was having phantom presses (it would press and release randomly).
So, I bought a new conductive film, thinking it was broken. I installed it, but I'm having the exact same problem. This time, the problem is with the Triangle and Circle buttons...
I checked the flat cable, and it's perfectly inserted and straight. Has anyone had a similar problem with their PSP? I don't know how to fix it.
UPDATE (06/25/26)
@dan0
I purchased this model, which is specified for 3000 models. It's the second one I've purchased, and I've changed suppliers.
The problem specifically occurs when I glue the film onto the console. Before gluing it, I connected both flat cables, and everything works fine. Once glued, the problems begin...
The film is perfectly centered (it follows the plastic pins for positioning).
1 Comment
Thank you for the update! That's probably it. I never glue it in, I just simply put it on the tape leftovers. I recommend doing that and see if that fixes it.
by
Add a comment
1 Answer
Most Helpful Answer
Hi!
Are you sure that you have the correct model?
Since the issue changes all the time (beginning it was X and O, then R1 and now the triangle and O again), indicates that it probably is the conductive film…
Where do you buy them? I would try a different seller and try again.. usually it is the conductive film that is broken in this case.
Score 1
Add a comment
Add your answer
Alex Mari will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 50
All Time: 50
