Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
Psp 1000 not turning on
So when I turn on the power switch for my psp 1000, power led lasts for 0.01 secs and does not turn on, pls help I searched but I didn't find any solution
Add a comment
1 Answer
Hi!
Did you replaced the battery already? They are known to get bad these days.
PSP 1000 Battery Replacement
I would do that first and see what happens.
If the issue persist, you may want to test another power switch and see if that solves it.
Is the PSP modded?
4 Comments:
Hello,
So I replaced the battery but it's still not working, battery charges normally but when I up the power button, it js blinks short green light for 0.01s and stops.
by
Alright. Is the PSP modded? Otherwise you could hold “R” while booting it up, should display the recovery menu. Is it also possible to try another power switch?
by
No, it's not nodded, I think has a problem with processor or ram
by
That is possible yes… in the worst case you need to replace them. Otherwise a motherboard replacement is required. They are not that expensive.
by
Add a comment
Add your answer
yassin raed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 69
All Time: 69
