The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
p0113 after changing mass airflow sensor
How many other causes can troubleshoot a code p p 013 other than the airflow sensor
Add a comment
1 Answer
Most Helpful Answer
@letishadel13644 that will all depend on the exact year and engine. The P0113 code means your engine's computer detected a voltage signal higher than expected from the Intake Air Temperature (IAT) sensor 1 circuit. That code is really not a MAF code but an IAT code.Let's assume you have changed the MAF and still get that code, you do want to go ahead and check the air intake temperature sensor. Check to make sure your intake temp sensor is connected or it may be bad. You'd be looking for something like this part Not an endorsement for the seller just an example.
Score 1
Add a comment
Add your answer
Letisha Delgadillo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 47
