Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
Is this going to cause me problems?
So I am doing the retrogem mod for fat ps2 and it requires to remove some components. I used a little too much and flooded two vias with solder I managed to remove the solder from the vias I used a 30 awg wire to make sure there wasn't any solder in the holes the wire went through without resistance. There is some left on the surface and that is where the flex cable will go over. can I put solder mask on them it as a precaution?
Add a comment
1 Answer
Chosen Solution
@christophe89153 yes, you could "put solder mask on them it as a precaution" but going by your pictures, this really would not be necessary. Looks like the overflow has not done any harm to the vias.
Add a comment
Add your answer
Christopher D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 110
