Outdoor fan is not working
The outdoor fan is not working but indoor is working
2 Comments:
Our fan behind is not also working
by
The maintenance said need to replace the coil is it real how
by
Add a comment
⚠️ 1) Power supply issue
  • Outdoor unit may not be getting electricity
  • A tripped MCB or blown fuse is common
👉 Check:
  • Your home MCB / circuit breaker
  • Whether the outdoor unit makes any sound when AC is ON
🌀 2) Faulty capacitor (very common)
  • The capacitor helps the fan motor start
  • If it fails, the fan will not spin
👉 Symptoms:
  • AC runs but outdoor fan does not move
  • You may hear a humming sound
👉 Fix:
  • Needs technician replacement (quick and cheap repair usually)
🔌 3) Fan motor failure
  • The motor may be damaged or stuck
👉 Symptoms:
  • Fan does not rotate even manually
  • Burning smell may appear
🧠 4) PCB / relay problem
  • Outdoor circuit board may not be sending signal to fan
👉 Fix:
  • Requires professional repair
🌿 5) Physical blockage / dust
  • Leaves, dust, or dirt may jam the fan
👉 Check:
  • Turn OFF power
  • Gently check if fan blades are stuck
Add a comment
also posible indoor board not send signal to outdoor block. check output signal on black wire using multimeter
Add a comment
Add your answer
Daljit Singh will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 68
All Time: 216
