Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in stereoscopic 3D on the top screen.
R trigger with copper pads ripped
Hello! I'm a beginner at micro-soldering and I'm working on a New 2DS XL. The pads are completely ripped. I need to install jumper wires to fix this, but I'm not sure where to safely scrape the solder mask to expose the underlying traces without damaging them. Any advice or reference on where to scratch would be highly appreciated!
Add a comment
Most Helpful Answer
Hi!
I think it's for the best to watch this video: https://www.youtube.com/watch?v=KI1QYaTv...
This should help you all the way :).
Please let us know how it goes!
Score 2
3 Comments:
Thanks I'm going to watch it in detail, thanks for your answer.
by
I'll let u know when I finish it
by
Alright! Good luck with the repair!
by
Add a comment
You're in luck; this should be easy to fix if you have the right skills.
First of all the two pads at the top are merely there to hold the button in place, the 3 at the bottom is what actually makes the console register the click. The left and right one I've circled in the picture is what I assume the ground of the motherboard, so simply soldering the wire on that golden triangle should be fine for the left pad. Now those two pads should be connected to each other since they're ground pads, but just in case they aren't you can scratch it open at the red circle I put on the image and fly a wire from there. The middle pad is independent of the other ones but there is a test point (pointed out in my image) so you can just fly a wire directly from there.
I don't have the motherboard diagram of the 2dsxl but judging from the image this should work.
To hold the button in place you can try some UV glue but it probably won't be as firm as it used to be, so be careful with the button after this repair.
Score 1
2 Comments:
Wow I'm impressed with this detailed answer, thanks a lot, got it and now I understand the function of each pads, I'll do that.
by
by
Add a comment
Add your answer
Juan J will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 17
All Time: 117
