A pair of wireless noise-cancelling over ear headphones released in 2022 by Sennheiser.
Can I do anything to save these?
The issue is 100% structural. The electronics are still working normally. The left laft is broken at the part where the length is adjusted. The plastic that has screw holes is broke. Both the outer channel broke, and the inner plasric part that moves inside the channel broke. Check the image for more details. the broken off piece of plastic from the outer channel is being held on my the fabric it is glued to.
I was considering glueing them back together. What glue should I use if that is a good idea and how do I go about it?
Can I fix them? How would one proceed here?
Add a comment
1 Answer
@florianpirvulet adhesives will not be strong enough for this. you would need to proxmarte the broken arts as tightly as possible to each other. Then fabricate a small piece of sheetmetal and apply it as a bridge across the two broken pieces. Use some small screws to attach the bracket. Finally, get some 2 part epoxy resin. Mix it according to the label and pour it over your broken pieces. The epoxy will harden to keep all those parts connected. Now, sounds easy enough but the problem will be, that you really don't want the resin all over the plastic. You will need to somehow create a form of some sort to ensure you just get the resin over the broken parts in enough thickness to be effective.
If this description is to abstract to follow, post some pictures with the broken part moved as closely as possible to where it broke off. I can then edit it and hopefully make more sense of what I am referring to.
Add a comment
Add your answer
Florian Pirvulet will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 62
All Time: 100
