Subaru WRX. Non-STI model Standalone model from the Impreza.
Passenger Windshield Washer Nozle
I have my 2019 WRX that for some reason isn't feeding any water into the passenger washer nozzle but works fine on the driver side. I don't see any obstructions in front of the nozzle? Are both nozzles connecting to the same hose coming from the reservoir?
Score 1
Add a comment
Most Helpful Answer
@louboo "Are both nozzles connecting to the same hose coming from the reservoir"; they are not. There will be a Y-connection which connects to each nozzle. It'll be under the cowl panel. Use theSubaru WRX Front Washer Nozzle to check/replace the spray nozzle.
Score 2
1 Comment:
This is great, I should be able to fix this without any issues now. I'll let you know what I find out 🤞
by
Add a comment
hey, are you getting anything? try emptying reservoir & put in warm water -possibly gunked up inside...if not im not positive but i have changed the hood nozzles & lines for quite cheap on amazon. id also use a pin to re-orient hole may have moved. ??? hope i helped?
Score 1
1 Comment:
I'll give this a try. Hopefully this works 🙇
by
Add a comment
Add your answer
Louboo will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 37
All Time: 115
