Up to 20% off select tools
Issue with Network adapter.
I am experiencing a persistent issue with my PC. Whenever I try to connect to a saved Wi-Fi network that has auto-connect enabled, it does not connect properly.
After running the troubleshooter, the connection gets restored. During troubleshooting, the process performs a network driver reset.
Attached are a screenshot of the issue and the driver details of the network adapter being used.
Please let me know if any additional information is needed to help resolve this persistent issue.
Add a comment
1 Answer
Go here to get more info
Persistent Wi-Fi connection glitches on a Dell Inspiron are usually caused by corrupt network profiles, outdated drivers, or aggressive power-saving settings. You can often fix this by "forgetting" the network and resetting your wireless adapter.
Here is how to quickly resolve the issue, ordered from the most common fix to advanced troubleshooting:
1. Forget and Reconnect to the Network
A corrupted network profile often prevents auto-connect from authenticating properly.
  1. Go to Settings > Network & internet > Wi-Fi.
  2. Click on Manage known networks.
  3. Select your problematic Wi-Fi network and click Forget.
  4. Reconnect to the network manually by selecting it from your Wi-Fi list, ensuring you check the box for Connect automatically, and re-entering your Wi-Fi password.
2. Disable Power Management on Your Network Adapter
Windows sometimes puts your Wi-Fi adapter to sleep to save power, causing it to fail when attempting to wake and auto-connect.
  1. Right-click the Start menu and select Device Manager.
  2. Expand the Network adapters section.
  3. Right-click your wireless network adapter (e.g., Intel, Realtek, or Qualcomm) and click Properties.
  4. Go to the Power Management tab.
  5. Uncheck the box that says Allow the computer to turn off this device to save power, and click OK.
3. Update the Wireless Driver
Outdated Wi-Fi drivers and BIOS frequently cause compatibility issues with modern routers.
  1. Open the pre-installed SupportAssist app on your laptop and run a scan to detect and install driver updates.
  2. Alternatively, visit the ⁠Dell Drivers & Downloads page, enter your specific Service Tag, and download the latest wireless driver specifically meant for your Inspiron 14 3000.
4. Perform a Network Reset
This wipes and reinstalls all your network adapters and returns other networking components back to their original settings.
  1. Go to Settings > Network & internet > Advanced network settings.
  2. Click on Network reset.
  3. Click Reset now and confirm. Your PC will restart automatically within five minutes.
If you want, I can help you locate the specific Wi-Fi adapter model in your PC to provide exact advanced driver settings. Let me know if the "Forget" option solved the issue!
Add a comment
Add your answer
Basil will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 50
All Time: 97
