How to upgrade from 128gig
Which part must I buy and how can I upgrade
Add a comment
1 Answer
Most Helpful Answer
Hi @granthattle
I assume that you wish to upgrade the 128GB SSD drive is that correct?
If so, here's the maintenance and service guide for Pavilion 14-bk000-099 models
Go to p.37 (45 of 90 pdf) in the manual to view the procedure to remove/replace the SSD drive.
At the top of p.37 you'll find the HP part numbers for compatible M.2 2280 sata III SSD drives.
Search online using the part number only of a higher capacity drive that suits you best i.e. 256GB or 512GB.
If you wish to increase the storage and performance in the laptop even more, you can also upgrade the HDD by replacing it with an up to 4TB 2.5" 7mm sata SSD. See p.35 (43 of 90 pdf) in the manual.
Score 1
Add a comment
Add your answer
grant hattle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 79
