Up to 20% off select tools
The Lenovo IdeaPad 3/3i 15ITL6 is a 15 inch variant the IdeaPad 3, based on the Intel 11th gen platform. There are multiple different models with different CPU, RAM and SSD configurations, however, repairing these all seem to be basically the same. Released in 2020.
Laptop Backlight not working
My laptop backlight is not working, the laptop itself works and when i shine a flashlight at it i can see what it displays, i opened the laptop and (by following a youtube video where the same laptop had the same problem) i noticed the fuse for the backlight was missing?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @marioskij
The backlight fuse is a 3A 32V type number is ERBRD3R00X
To verify that it is the correct fuse location that you're looking at, if the motherboard is an NM-D471/NM-D472 model, here's an image showing the location of the backlight fuse FV1. The top image is a zoomed in image showing the location and the bottom image is an image showing the entire board that you can use as a reference to verify.
(click on image)
Here's an image from the schematics for the board showing the backlight power circuit (+LEDVDD) to the eDP connector
(click on image)
Score 1
Add a comment
Add your answer
marioskij will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 23
Past 30 Days: 93
All Time: 377
