Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Battery or Tristar U2 IC
Old phone will boot loop while plugged into wall charger but then when plugged into a computer does nothing and can't turn it on. is it Battery or Tristar U2 IC. How do I fix it?
Score 1
Add a comment
1 Answer
A boot loop while connected to a wall charger can be caused by either the battery or the charging circuit, so it's hard to say from that symptom alone. The fact that it behaves differently when connected to a computer does make the charging path worth investigating, but I wouldn't jump straight to a Tristar/U2 diagnosis.
I'd start by checking the battery first, especially if it's an older device. Also, if the phone is able to generate logs, run an iPhone panic log analysis. The panic logs can sometimes point to whether you're dealing with a battery/power issue or a deeper hardware fault.
Add a comment
Add your answer
Nathan Wyland will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 64
