The Cricut Maker 3 is a smart plotting machine designed to be used by at-home crafters. Released in June 2021. Model number CXPL303.
How to replace the ribbon cable?
I replaced the dc power barrel connector on my cricut. But when disconnecting the rinbon cable I broke the plastic clamp connected to the board and cant get the cable to stay in place.
1 Comment:
@lesleycraven270t a picture of what this all looks like. I sounds like you are saying that the cable lock on your Zif connector broke. We will need to see that to make sure. Adding images to an existing question
by
Add a comment
1 Answer
You'll need to open the controller, disconnect the old ribbon cable from the ZIF connector, and carefully install the new one in the same orientation. Be gentle with the locking tab—it's easy to break. If you can share the controller model, it's easier to point you to a specific guide or replacement part.
Add a comment
Add your answer
Lesley Craven-Hutchinson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 34
All Time: 174
