The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
Flashers randomly coming on
Hazard light are randomly coming on when parked. This then drains the battery.
Add a comment
1 Answer
Randomly activating flashers are usually caused by a faulty turn signal switch, hazard switch, or a wiring short. Start by checking for loose/corroded connectors and inspect the flasher relay. If the problem occurs when hitting bumps or turning the steering wheel, the switch or wiring is the most likely culprit.
Add a comment
Add your answer
Pam Pivec will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 146
