The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
My F1 fuse keeps blowing.
The F1 fuse on my SNES keeps getting tripped. As soon as I plug in power the fuse blows. I’ve checked the voltage regulator and It seems good. I can’t find any other glaring issues but clearly there’s a short somewhere. Any help would be appreciated!
Add a comment
1 Answer
To check the voltage regulator u need voltage that u wouldn't have if the fuse is blown. Fuses blow because of a high current drain over their rating. The first thing to check would be the power capacitors since that is mostly visual, leakage and/or expansion. However, the most common cause is bad diodes in the power supply. So, put your DVM in diode mode and check all the diodes and large 3 terminal devices. After that it would be a shorted component on one of the power rails, which might be detectable using a DVM with a very low resistance range.
Add a comment
Add your answer
JThorn90 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 58
