First unveiled in December 2016. Identifiable by model numbers 20HD00xycc where "x" is a number, "y" is a letter, and "cc" is a country code.
The display not turning on
Actually, this is a bad one My sister used my laptop and for some reason after she used it, the display is not turning on anymore then i found a dint near the screen and it seems like something heavy fall on it. The Laptop is still functioning i can connect it to my monitor and it functions well but the screen on the laptop it self is not functioning, what should i do? is it fixable without buying a new screen? Please help thank you!
Add a comment
1 Answer
Since the laptop works normally on an external monitor and there's a visible dent near the screen, the internal display or display cable was likely damaged by impact. Unfortunately, this usually isn't fixable through software. Have a technician inspect the screen cable first, but a screen replacement may be necessary.
Add a comment
Add your answer
Kerbie Yase Fernandez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 15
All Time: 106
