How to repair my screen
how to repair my bent screen
@magydee2004 if it is just your screen then you will have to replace the display. If it is your whole phone housing, you can try and bend it back or you will need to replace that as well. That is a pretty big job. Without us seeing the actual damage and only going by what you are saying, I would say start with the display.
Also, why is it bent? If it is because you have it in your back pocket or similar, then you will have to stop doing that :-) but make sure it is not because your battery is swelling up and moving the display. Check your battery when you replace the display.
Since iFixit doe s not yet have a guide for this, use something like this video to change the display. Replacements are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 46
All Time: 393
