Released November 1998, identified by model number HKT-3020.
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
8 Comments
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
Adding images to an existing question
Thank you.
by
Can I upload video? pictures won't help
by
Yes you can!
Using Media
Thank you
by
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
by
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
by
Show 3 more comments
Add a comment
1 Answer
Chosen Solution
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
3 Comments:
Alright. Then it is normal behaviour. Thanks for sharing!
by
Sorry for the delay thank you
by
No problem at all! Have a great day :)!
by
Add a comment
Add your answer
Christopher D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 189
