Up to 20% off select tools
How to fix broken wire
How to fix my broken wire it only works when it is bent
Add a comment
1 Answer
Not much you can do to fix the wires, you really need to replace the full cable assembly. Depending on the device the manufacturer might offer a replacement cable or you might be able to splice in a replacement cable using a standard USB-C cable that meets the needed wiring requirements.
Add a comment
Add your answer
Shazia Sadaf will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 50
All Time: 280
