Tv is not getting on
When we were watching it automatically switched off and we started it again by putting on button after 5 minutes also it didn't on
Add a comment
1 Answer
Most Helpful Answer
@shekhardhupe sounds like your power board may have failed. Let us know if you still have the power LED turn on. IF not, remove the back cover after you unplug your TV. Then check the power supply and look for the fuse on that. Measure it to see if it still has continuity. Also, take some good pictures of all of your boards so we can see what you see and hopefully we can get your TV back to working again.
Adding images to an existing question
Score 1
Add a comment
Add your answer
shekhar dhupe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 141
