The ninth generation of Chevrolet Impala debuted for the 2006 model year. This generation of Impala was offered as a front wheel drive four door sedan, and was powered by a wide range of V6 engines. Production continued for fleet versions until 2016 under the name "Impala Limited".
Where to put antifreeze?
Where do I putWhere do I put the antifreeze in my twenty fifteen impala
Add a comment
1 Answer
Many GM vehicles don't have a radiator cap but the coolant container cap is GMs pressure rated cooling system cap. The coolant container is pressurized too, so unscrew the cap after the engine cools down. Fill to the COLD level. After engine warmup, coolant expands with the coolant level rising in the container and lowers when coolant cools down. The remaining air gap and plastic pressure cap effectively prevents coolant from oxidizing for long life coolant. The air gap allows coolant to expand and contract without leaving the container unless the engine overheats with pressures higher than the pressure cap rating.
Add a comment
Add your answer
Dee Bridgeforth will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 108
