The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
Why are my valves chattering
Why are my valves chattering?
1 Comment:
@poeqjdyfxs4qurr what engine size is it? Post a short audio file with your question that way we an hear what you hear. You do that the same way as you would do to add images Adding images to an existing question
Some of the Jeep engines had issues with the rocker arms.
by
Add a comment
1 Answer
it is likely your lifters, not your valves. When the lifters go out of adjustment they start making tapping noises.
They may just need adjustment or they may need replacement.
Add a comment
Add your answer
B S will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 83
