armature seperate from housing
How to detach the armature from the housing
To detach the armature from the housing on a Ridgid R4030 tile saw, first, unplug the unit and remove the motor cover, motor brushes, and collet nut. Separate the two halves of the motor housing, disconnect the LED light wire, and then gently pull or tap the armature out.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 78
