I have Meizu C9
It's a old phone wondering if I can bring it back to life. The power button is missing and the battery a bit largen
Yes, you can likely revive your Meizu C9, but the swollen battery must be handled first for safety. Replacing the battery is essential, and you can bridge the missing power button using a small conductive object or a repair kit. Here is how to bring it back to life:Safety First - Battery: A "largen" (swollen) battery is dangerous. Stop using it immediately and dispose of it at a local hazardous waste facility. Buy a replacement battery for the Meizu C9 (BL-F610) online.Fix the Power Button: With the back cover off, look for the small tactile switch on the motherboard. You can gently press this switch with a plastic toothpick or plastic spudger to turn it on.Startup Method: If the battery is dead and you have no button, plug the phone into a charger and hold the volume down button to enter fastboot mode, then use a computer to reboot it.Long-term Solution: Search for "Meizu C9 power button flex cable replacement" or simply use a case to hold a small piece of plastic over the tactile switch to act as a button.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 85
