This generation of Suzuki Alto became widely available in 2009. This generation shares many features with its sister cars the Mazda Carol and the Nissan Pixo.
Why my ac not cooling sufficiently
Add a comment
1 Answer
Most Helpful Answer
If blower fan speeds are working, there's a possibility of wear and tear from leaks releasing refrigerant over time. The best way to determine if a leak occurred and following up with repairs, is using dye along with r134a. Greenish yellow dye circulating in a system will leak out with invisible refrigerant and oil. Dye and oil mark where leaks occur. An inexpensive uv blacklight makes dye glow under darkness, Do not use sealer otherwise contaminating a system may create problems. Repair shops may refuse to repair systems with sealer contaminating their equipment. Ac repairs are not diy friendly unless having more than casual knowledge of refrigeration, diagnosis, troubleshooting, repairs, and using ac equipment.
Score 1
1 Comment:
Thank you very much
by
Add a comment
Add your answer
AF A will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 20
All Time: 57
