Smaller brother of 300 in 6cy coupe.
Motor is locked can this be fixed
How to unlocks motor
Add a comment
1 Answer
@fernandoro78917 generally yes but it will require a teardown and then a rebuild to eliminate the damage/reason from having been blocked. If you know what happened to that engine then you can also figure what needs to be done. Depending on the year, mileage etc. it maybe time to consider replacing the engine unless you have the right connection for the rebuild since it will require some machining.
Add a comment
Add your answer
Fernando Rodriguez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 10
All Time: 10
