Up to 20% off select tools
Color All-in-One Printer/Fax/Scanner/Copier
Prinhead removal and replacement
How are the printheads removed from a HP Officejet Pro L7580?
Add a comment
Most Helpful Answer
Hi @lesliebond
Here's the ifixit HP Officejet Pro L7580 Teardown guide that might help.
Also a link to the parts list if needed. Search online using the part number of the wanted part to find suppliers that suit you best.
Score 1
Add a comment
Slide open the cartridge access door. Pull out all of the ink cartridges and then flip up the grey lever/handle that tha print heads rest on. Then you can carefully pull out the print heads straight up.
Add a comment
Add your answer
Leslie Bond will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 121
