Smart tv with 3D 1080 display.
Toshiba tv issue need help
Why since my Toshiba tv updated software does my TV when putting on in morning go straight to a channel instead of the way it was the Toshiba and android logs starting up
Add a comment
1 Answer
Most Helpful Answer
Hi @michaeldeanie02
"Try this....
  1. Check Startup Settings
    • Press the Home button on your remote.
    • Go to Settings > Device Preferences > Power On Behavior (sometimes listed as Inputs > Power On).
    • Change the option from Last Channel or TV Tuner to Home Screen.
  2. Disable Auto Channel Update
    • Go to Settings > Channel Settings.
    • Turn off Auto Channel Update if enabled. This prevents the TV from forcing channel mode at startup.
  3. Check Input Source
    • Navigate to Settings > Inputs.
    • Ensure the default input is set to Android TV / Home instead of TV Tuner.
  4. Firmware Updates
    • Check for any newer firmware under Settings > About > System Update
Score 1
Add a comment
Add your answer
Michael Deanie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 22
All Time: 154
