How I can replace transmission oil
How I can check transmission oil level
@mandeepmaan here are the Atfinstructions for the Ford PowerShift DPS6/6DCT250 which is one of the transmissions used in your Fiesta. Essentially, you open the drain plug to drain the ATF (on a warm transmission only) and use the filler plug to add ATF. You will need to fill until it starts to leak back out of the filler plug.
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 112
All Time: 706
@mandeepmaan what exact year and model is your Fiesta and I assume you are referring to an Automatic Transmission?
by oldturkey03
