The 5th Generation Hilux introduced in 1988, produced a longer-wheelbase option, 3,099 mm (122 in) rather than 2,616 mm (103 in) for the regular wheelbase. Its one-piece cargo-box walls eliminated the rust-prone seams that were found in earlier models.
My battery is not charging
Car battery not charging
Add a comment
1 Answer
If your battery isn’t charging, it’s almost always the alternator. If you can, check it with a multimeter ,with the car running it should be around 14 volts. If it’s below 13, the alternator isn’t charging the battery.
Add a comment
Add your answer
Petrus Steven Stefanus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 119
