not cooling only create a sound
not cooling and air only creat sound
@jassibal if your fan runs and all but the generator does not kick in,(you should hear it kicking on) then it is possible that the compressor might be damaged or the unit may have a refrigerant leak. Verify that your AC is a BXAC40008GB and let us know what you have already checked (i.e. filters, thermostat, checked for blocked exhaust etc.) Make sure that you are in cooling mode. This model uses Propane as refrigerant so you should consult a professional AC person to work on it, in regards to the possibility of recharging. BLACK & DECKER BXAC40008GB MANUAL
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 95
All Time: 136
