Why is my car stalling at a stop.
Car stalls at a stop .
With this type of car and what you are describing it sounds like a lack of airflow that is causing it. When you are moving the car is getting a load of airflow into the car which helps keep the car ticking over, but the second you stop, you get no airflow and the car stops.
I would suggest check all your filters to make sure they are not blocked or clogged up.
Failing that, it could be sensors like the MAF which is an airflow sensor, this is likely to be your next problem.
The next thing I would look at is your fuel delivery and ensure you fuel pump is in working order.
Always check your fuel and air if you car randomly stops!
I hope this helps!
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 30
All Time: 30
