Repair guides for the Huawei Nova Android smartphone, released in October 2016. The Huawei Nova is a mid-range smartphone with a 5 inch 1080p IPS display, fingerprint sensor, and 12 MP rear camera.
Why is my phone over heating
My phone overheating
Add a comment
1 Answer
A phone can overheat for several reasons, including:
  • Running heavy apps or games for a long time
  • Too many apps running in the background
  • Charging while using the phone
  • Weak network signal causing the phone to work harder
  • High screen brightness
  • Hot weather or direct sunlight
  • A faulty battery or charger
Try these fixes:
  1. Restart the phone
  2. Close unused apps
  3. Lower screen brightness
  4. Remove the phone case while charging
  5. Use the original charger
  6. Update the phone software
  7. Avoid using the phone while charging
If the phone still gets very hot even when idle, the battery may need replacing or the device may need repair.
Add a comment
Add your answer
Dennis Lupiya will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 83
