The Maxima was redesigned for the 2009 model year and made its debut at the 2008 New York International Auto Show.
A P0420 code means "Catalyst System Efficiency Below Threshold (Bank 1
How to fix it
Add a comment
1 Answer
@tejpal89202 there are a few things that could cause this The most common one is a failing catalytic converter. It can also be caused by an exhaust leaks, or a bad downstream O2 sensor, intake air leakage etc. Use the 2014 Nissan Maxima Engine Controlchapter form the SM and go to page 304. Here you'll find what to check and how to diagnose and ultimately proceeed to get this fixed. Let us know if you need more help on this.
Add a comment
Add your answer
Tejpal will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 26
All Time: 26
