Up to 20% off select tools
The DeWalt DW274 is a corded drywall screwdriver.
How to change bits?
how to change bits?
Add a comment
Most Helpful Answer
Have a read of this manual. The very front piece should come off. Either twist off or bayonet fitting. The the next section comes off.
https://share.google/fYZEYVu36W4ADoI2l
Score 1
Add a comment
The collar comes off if you pull forward, revealing the bit holder. To put it back together you just need to line up the ribs on the collar with the grooves on the machine. I added the relevant photos
Hope it helps!
Score 1
Add a comment
Add your answer
David Adams will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 34
All Time: 158
