How to replace a glass top of stove
How to replace the glass top of my new stove
1 Comment:
Hi @johnwalker27778
What is the model number of the stove?
Since the stove is new, was the glass top faulty due to manufacturer or user?
If manufacturer, get it fixed under warranty.
by
Add a comment
1 Answer
1. Turn off power
Unplug the stove or switch off the breaker.
2. Remove the top panel
Open the oven door and unscrew the bolts under the front edge. Lift the glass top up.
3. Disconnect wires (if attached)
Some models have connectors—carefully unplug them.
4. Take off the broken glass
Remove it gently (wear gloves).
5. Install new glass top
Place the new one, reconnect wires if needed.
6. Screw it back & test
Tighten screws, restore power, and check if it works.
Add a comment
Add your answer
John Walker will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 28
All Time: 122
