Haier THASNQ286TM5-84 - Toplader
It's really not that bad a vibration.
The amount of vibrations during the spin cycle can depend on how the clothes have been left distributed around the tub during the washing/draining cycles, before it starts to spin.
For example, if heavier clothing has ended up on one side of the tub then the tub is not balanced and will begin to move about as it is spinning.
Most washing machines have an out of balance sensor that will stop the machine if the drum starts to move about too much.
Once a machine gets older the suspension springs and shock absorbers that are used to hold the tub in position start to wear and lose tension so the machine may begin to stop often during the spin cycle with an out of balance error being displayed.
It seems like it's a fairly recent model, so if you're still concerned and if it is still within the manufacturer's warranty period, contact the Haier service centre in your location and get them to check if it is OK
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 31
