Repair and disassembly guides for the Nintendo Switch OLED Model, announced and released in 2021.
Why does the joy con detach off so easily?
Why does my Joy-Con detach so easily without pressing the button designed to separate it? I mean just pulling it
Add a comment
1 Answer
Most Helpful Answer
Hi!
That is most likely caused by the buckle locks which can be found inside the joy-cons.
These are made of plastic and causing it to break very easily. The rail is made of metal and this causes it.
The only thing you can do is to replace those buckle locks. Since this is very comon, you can buy metal buckle locks which last very long. I recommend to install new metal ones. They are not expensive at all.
Guide: Joy-Con Buckle Lock Replacement
Please let me know if you have any questions!
Score 2
1 Comment:
I would definitely recommend metal buckle locks. They're sturdy and won't fail in a year or two even if you detach them every day. I've got them installed on my Joy-Cons & so far they've worked perfectly for a year of attaching/detaching
by
Add a comment
Add your answer
حسين علي will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 27
All Time: 104
