Chrysler debuted the 2008 model year Town & Country went on sale on August 16, 2007 as a 2008 model.
Power steering fluids leaking on passenger side
My power steering fluid is leaking on passenger side front is it most likely the rack or hose
Add a comment
1 Answer
@amberchesebro most likely it's the rack but hopefully just the hose (easier fix ;-). We will need to know the exact year and model for your Town & Country. To make a good determination where it is coming from. Use a pressure washers and wash the engine and the frontend (rack and all). Then let it dry or a bit. Now, and be careful with that (always use chocs and set the parking brake to make sure your vehicle is not moving) turn your T&C on. Get in a position near your vehicle where you can see the power steering hoses and the rack itself. Have somebody move the steering wheel all the way left and all the way right. See if that help you to find the leak. A leaking hose is almost immediately visible while a leaking rack may take some time to push through the seals etc. Let us know what you find out.
Add a comment
Add your answer
Amber Chesebro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 24
