Toyota released the 2002-2006 Camry XV30 series as a larger sedan in September 2001 for the 2002 model year.
How to change driver side door
I want to change the driver side front door
Add a comment
1 Answer
@azeezhamzat in theory all you have to do is to remove the bolts that connect the door hinge to the frame. You could use the SM (found on this page 2002-2006 Toyota Camry under teh Documents header) page 1224 to work on it or you could just checkout this video. It shows the passenger door but it will be the same for the driver side.
Add a comment
Add your answer
Azeez Hamzat will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 24
All Time: 160
