Founded in 1862 and based in Rüsselsheim, Germany, Opel is a historic automaker. After nearly 90 years under General Motors, the company was acquired by the PSA Group in 2017 and is now a key brand within the global Stellantis conglomerate
Car cranks but does not start
Car cranks but does not start , fuel is getting to injectors & spark plugs are getting spark
Score 2
5 Comments:
Did you check for a blown injector fuse? Fuel to injectors doesn't mean injectors are firing.
by
@nqobizitha what year, model and what engine size is it?
by
2009 petrol 1.4
by
@franklyndaniels so you have the same issues as the OP? What have you already checked and what have you already tried? What model is your Opel?
by
Gadi start nahi ho rahi hai
by
Add a comment
1 Answer
Fuel reaching the injectors and spark at the plugs are good signs, but that still does not prove the engine has everything it needs to start. I would check three things next: injector pulse, fuel pressure, and compression/timing.
First, make sure the injectors are actually being commanded to fire with a noid light or scan tool. Fuel at the rail/injectors does not mean fuel is entering the cylinders. Then check actual fuel pressure, because weak pressure can still give a no-start. After that, do a compression test and verify cam/crank timing, especially if it cranks faster than normal or sounds uneven.
If there is spark but no injector pulse, I would look at ECU inputs such as the cam/crank signal, immobilizer status, and wiring. A failing camshaft position sensor can sometimes cause a crank/no-start even when other basics seem present.
In short: confirm injector pulse, correct fuel pressure, compression, and timing before replacing parts.
Add a comment
Add your answer
Nqobizitha will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 152
All Time: 469
