The 2015 Tahoe was later named the fastest-selling vehicle for the month of February 2014, averaging seven days of sales upon its release.
Windshield washer not working
Add a comment
1 Answer
Most Helpful Answer
Hans, you're going to have to do some troubleshooting here. Does this affect the front or rear washers or both? On the front, does the left or right side work, or neither?
I suggest checking a few things then come back and tell us what you find.
  • First, can you hear the motor run when you activate the washer?
  • Are the hoses leading from the pump to the nozzles on and secure?
  • Does water come out somewhere under the hood instead of the nozzles?
  • Do you have voltage going to the motor when you turn the switch on?
  • Have you checked the fuses?
  • And finally, it does have fluid in the reservoir, right? (Just covering all the bases.)
Do as much of that as you can, then let us know the results of your troubleshooting and we'll see what you should do next.
Score 1
Add a comment
Add your answer
Hans Guzman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 125
